Dustinp
- May 6, 2021
- 39
- 13
Kazen Racing Pro 2 Sandrail
Chassie specs
103 wheelbase
4130 chassie and suspension components
20 inches of front wheel travel fox coilovers
18 inches of rear travel, fox coilovers & 4 tube bypass shocks
All shocks were rebuilt 3 trips ago
Suspension tuned by Joe Moore from Fox race team
2 inch hollow spindles
Front and rear brakes
Douglas billet beadlocks all around
Rear tires Dune sports 14.50 ×15
Front tires are Sand Tires Unlimited Razorback 8.50
Cutting brakes
Saco steering rack
Electric power steering
Full body by Car One with windshield
Lowrance GPS
Rugged radios intercom RRP660 with Bluetooth
Rugged radios radio Vertec
22 gallon fuel tank
Mastercraft seats
Onx 40 inch light bar
Eagle Eye lights
Outfront Motorsports
Has 11 trips since motor was built
600 hp 2.6 stroker dual Overhead cam
Closes deck block with 1/2 head studs
Turbo pistons
H beam rods
Wrx heads with chrome valve covers
Shaved and polished intake manifold
Race bearings
High volume oil pump
Windage tray
Garrett G-660 72 ar water cooled
50 mm Tail wastegate
50 mm Tial Blow off valve
150 amp alternator
CBR 19×31 radiator with 2 16 inch spal fans
CBR 16× 18 intercooler with 16 inch spal fan
Total power 1500 battery
Car has 2 stage boost controller. It was tuned to 600 hp by John at Outfront Motorsports. Low boost setting is 15 psi (496 hp) and is all you need.
Weddle 2d with pbs shifter. 3 trips since rebuild.
Car weights just under 1600 lbs and is a blast to drive. Slides like a Funco due to the dunesports tires.
$26,500
Chassie specs
103 wheelbase
Cutting brakes
Saco steering rack
Lowrance GPS
22 gallon fuel tank
Mastercraft seats
Eagle Eye lights
Turbo pistons
H beam rods
Race bearings
Windage tray
150 amp alternator
$26,500
