ranman5608
- Jan 23, 2023
- 148
- 209
AS THE TITLE SAYS DOES ANYONE HAVE ONE THEY ARE WILLING TO LET GO OF OR KNOWS WHERE TO GET ONE.
TIA
TIA
yes, i have called, emailed and messaged on facebook with no response.Have you tried Summers Bros in Ontario? 1 909 395 5555
You doing the hub prep yourself? Those things are not easy, I learned the hard way years ago.
Thank you lambro.I have one and you are welcome to borrow it…. But would recommend having Kent @ Lothringer Engineering rebuild them.
Matt
Fivesixtwo 254 4353 text
@Lambrois correct. Not many people can do them correctly and every set it different.Thank you.
That makes sense. If that's the case that does complicate things. machining isn't necessarily a problem but I will need to do some research to find out what the proper preload and torque specs are.
