2004 Funco gen 4 with 2D and 2.5 turbo Subaru (SOLD)
JM PRO
2004 Funco Gen 4 with 2D and 2.5 turbo Subaru
Up for sale is a beautiful Funco Gen 4 built and assembled by Funco. Car has a unique history. Car was used for a few years then sat for over 10 years in a garage and not used. After the car came out of its hibernation, the car went to the shop and had a long list of work done to it. John at Outfront has had it twice and over 16K was spent with him on new parts and Dyno time. LRS also had the car and rebuilt the drivetrain including rebuilding the mid board hubs and race prepping the 930 CV’s. The 2D Mendeola tranny was rebuilt right before it went into storage. John replaced everything basically bolted to the engine, including new header, turbo, intercooler, injectors, fuel rails, fuel lines, fuel pump, intake manifold, throttle body, wastegate, BOV, and the list goes on. I also bought new seats, new belts, new front and rear tires, installed a AEM digital boost controller and the AIRLIFT 3P digital airbag system to lower and raise the car. Has new whips with remote control to change colors, center console storage, new master cylinders and rebuilt calipers. All bypass shocks have been rebuilt. John Tuned the car on E85 fuel and on the top setting of the boost controller it made 515 HP at 22 pounds of boost!! Lowest setting is 15 pounds of boost and made 355 HP. This car hauls butt and is truly a turnkey car. I had zero issues with this car and it ran flawless. Car has Rugged intercom system with car to car radio.  Below is a itemized list of new parts. Have all receipts for the work performed. SOLD
New parts:
Engine parts:
New turbo and new header with heat shield
New wastegate
New blow off valve,
New intercooler with fan and scoop
New polished intake with new throttle body
New air filters with outwear
New injectors, fuel rails and fuel lines including filler and breather lines for fuel tank
New fuel pump
New Timing belts and carbon fiber covers
New valve cover gaskets
New stage 4 pressure plate, new lightened flywheel and new 6 puck clutch
New AEM digital boost controller
Other new parts
New rear 14.50 paddle tires
New 33 Baja Pro shaved front tires
New Master cylinders with new slave cylinder
New PRP seats with double diamond stitching.
New Crow 5pt belts
New steering wheel
New Airlift 3P digital air bag system with 5 gallon air tanks and a Air chuck by the rear tires
