danwalker
- May 6, 2021
- 250
- 248
anyway you can post links to what you used - I have a 38ft 5th wheel and was going to throw up a couple pannels and add 2 more 6Volt batteries to the 2 I have now........This may be an easier way to go - we run our gennerator at mealtimes for the microwave. I use the inverter to power the tvs and the starlinkI would up grade current batteries to LiFePo4, add a second large amperage changer (125A ish) and run your onboard generator 1 hour a day to top them off.
Just bought a new to me Super C rv. Does not have solar. Has an AC fridge
any opinion on the Jackery solar generators?
Or do I bite the bullit and install solar system?
When AC is on I run the genny
I assume this is in the propane compartment? What did you do with the factory genesis charger? I was thinking of just doing the charger and batteries for now, I just gotta find itI have tweaked the diagram a little to add a second set of buss bars and a Victron bluetooth shunt right after the batteries to watch battery level and left the other shunts to monitor each charger level. I also added two more 100AH batteries for a total of 500AH with room to add three more if i feel the need. I run residential refrigerator and Starlink 24/7.
I use the 100AH non bluetooth batteries and then rely on a shunt to tell me Bluetooth info.
WattCycle 12V 100Ah LiFePO4 Battery - Group 24
Upgrade to WattCycle’s 12V 100Ah LiFePO4 Battery – 50% lighter than lead-acid, 10+ year lifespan. Group 24 size. Perfect for solar & RVs. Get yours today!www.wattcycle.com
My Onan 5500 will run the two added Rec Pro chargers and the built in 75 amp no problem, but nothing else. Run the micro wave and pop a breaker. I normally leave the 55 amp charger off unless my batteries are very low and i need a quick zapp.
Chargers i used
Shunts
yes in propane compartment then just to the left i have two more platforms for 4 more batteries in another compartment.I assume this is in the propane compartment? What did you do with the factory genesis charger? I was thinking of just doing the charger and batteries for now, I just gotta find it
I'm concerned about keeping the fridge running. The coach minds the batteries automatically, if they are low, 11.7v it will fire diesel generator until they hit target, 13v.What do you want solar for?
Mine just keeps the batteries charged. That's all I need it for.
I’m all electric and don’t have solar. The residential fridge doesn’t use a ton of power. With a decent battery bank you would just run the generator a few hours in the morning and in the evening.I'm concerned about keeping the fridge running. The coach minds the batteries automatically, if they are low, 11.7v it will fire diesel generator until they hit target, 13v.
It would be nice to take the fridge off the grid.
The old weekend warrior of 15 years ran on propane so it was never an issue
