New to me 4 seat SU Ultra lite
At some point if you swap out the front arms, you can fit bypasses too. Bypasses on a ultralight make it a completely new car
View attachment 141668View attachment 141669
Did you still use the 8” coil and add the 10” bypass? Who did the work? My car is at SU right now and they are fitting both a 10” coil and bypass but they have to lift the mid rail and shock mounts plus new arms to make it all fit.
Ed at SU did the suspension work.
King Adam did the body
If I recall the fronts are normally 9in.
I got all new shocks and bypasses - custom made 4 tube bypasses for front ( they were a 1 off )
Kings lengths don’t work very good for SU and fox stopped making the small ones. Hence why Ed has to raise mounts
Either way, with new arms yes they can fit, car will be wider, but that just makes it drive even better and gives more travel
Started life as pristine SU UL
Then king Adam, outfront, and SU did their thing with cubic dollars thrown at it
Then revamp again w ls3 and went all black. New owner still runs it around glamis
That makes sense now. Unfortunately my car already had kings all the way around and Bypasses in the rear already. I am pumped hearing about how much better it handled and the ride quality improvement.
I have a SU UL as well , with the ls3 was it still 5 link in rear ? If so do you have any close up shots ?
Finally got around to working on it
Old CVs and axles were cooked. I didn’t bother cleaning the CVs to see if anything was salvageable for spares.
New CVs and axles went in smoothly.
The car came with 6.80 front tires and 14.50 rears. They’re pretty beat up so I ending buying a set of used 8.50 fronts and 16.50 rears on FB marketplace.
I couldn’t get the old front tires off the front wheels so off to the tire shop tomorrow. Hopefully I’ll get the newer tires on and post a new pic tomorrow.
Still need to take the shocks apart and rebuild them and figure out how to adjust the shifter. It’s hard to get it in gear, a lot of play, and it started going into reverse when shifting to 2nd without pressing down on the shifter
  • IMG_4511.mov
    IMG_4511.mov
    17.2 MB
If I can make a recommendation for the shifter, I would ditch the one you have and go with a pro am unit. I tried adjusting the old one and could never get it right.
I was going to reach out to you to ask about the shifter since you have a similar car. Getting a new shifter is not in the budget right now so will have to make this work for the next few trips to St Anthony and Little Sahara.
I had a ProAm shifter in my last car and it was great. Would definitely consider this in the near future
We got it to run up Olds with a full-tilt Outfront 2.5 foot to the floor at the shittiest middle section with basic valving and just turning screws. 5-link cars have always handled well, just not handled whoops well.
Holy shit balls! Didn’t think anyone had done this to an ultralight. More info and pictures please!! Who did the fab work?
I’ll cancel the shock parts order right now! lol
I saw another five link SU that had bypasses in the rear but they were pointed in towards the motor almost like a arm front end, with the bulkhead in the center of the car. Similar to a Chenowth.
I spent a lot of time trying to get my rear to work and play like the big dogs, but it just was never going to happen. Not unless I was willing to put in 5k a corner... What it lacked in the whoops and g-outs, it made up for duning like a slot car though.
Spend time aligning the rear the best you can. It gets pretty squirrely If not setup right. If you find yourself doing a lot of adjustment on the heims, when you're all done, cycle the suspension and check your axle shaft lengths, or you could rip links off the frame. Ask me how I know.
Yeah I've seen 2 SU ultralites like the one you are describing. There was one on FB marketplace recently and I was going to purchase it but the seller did not want to budge on the price. If anything i would add the rear bypasses like the blue car in this thread later on. Doesn't seem like too much fab work is involved besides adding the upper and lower shock mounts.
do you have any advice on how to align the rear end besides double checking the axle length? are there any measurements that I should be aware of?
i was thinking of contacting Ed at SU for advice as well.
