EastMT
- Jul 21, 2022
- 947
- 609
I did see and remove the snap ring. Should have included that. If my hands aren’t to greasy I’ll take some better pictures when I do the other side.After removing the snap ring on the back side… (I maaaaay have forgotten once)
I usually use a punch to shove the outer bearing out from the inside, pull the spacer, then drive the inner out with a large socket.
Don’t forget to pull the wheel/cotter pin off and re-torque after the first run.
All the ugga duggas?I did see and remove the snap ring. Should have included that. If my hands aren’t to greasy I’ll take some better pictures when I do the other side.
What is the magic torque number for the big nut oh wise one?
