Pro r seat upgrade. 2025 seats in a 2022
megadesertdiesel
I found some take off seats from a 2025 Pro R and made them fit in my 2022.
The 2025 seats have fans on the back and heaters in the base. Easily wired up to a switch panel. The 25 seats have alot more cushion than the 22.
I would have thought they dropped right in but the base is a little wider.
I had to cut the metal cradle part out of the outer rail and it snaps in just like the original seats.
I did upgrade the thin aluminum cross tube inside seat to some 1” stainless steel tubing I had laying around.
Very "cool" upgrade 😎
They do look more comfortable and wider support.
I got the passenger seat base modified and works well!! Even used the VHT chassis and roll cage to touch up where I clearanced the stock brackets almost perfect match!!
