Jan 14, 2025 Thread starter #41 ChasingSand Well-known member Joined May 5, 2021 Messages 1,213 Reaction score 735 Better picture of the system. Should be good to hold 14LBS all day now.
Jan 14, 2025 #42 Dodd Active member Joined May 8, 2021 Messages 124 Reaction score 101 looks good, Hope to see ya out there.
Jan 14, 2025 #43 JM PRO Active member Joined May 5, 2021 Messages 222 Reaction score 176 It doesn't look welded. Do they machine the case and then press in the aluminum stiffeners?
Jan 14, 2025 Thread starter #44 ChasingSand Well-known member Joined May 5, 2021 Messages 1,213 Reaction score 735 JM PRO said: It doesn't look welded. Do they machine the case and then press in the aluminum stiffeners? Click to expand... They are not welded. They take an exact measurement of the block you send them, then they cnc the block and guard to be an exact match. Then it is pressed into the block. Here is a cutaway picture of one used on a B series motor.
