EmpirE231
- Aug 12, 2021
- 637
- 501
last time around I gave it a good cleaning with a carb cleaning kit, and carb spray. Fired up quick, revved and idled perfect... just kept pouring fuel out onto the floor through the overflow line.If you don't drain your gas before storage the jets get clogged. Pump gas is the culprit. My guess it's the pilot jet and needle seat valve (controls float level) are dirty. Could be also be possible that the needle float valve is not sealing and needs to be replaced. I use carb or brake clean and strands of 12 or 14 gauge wire to clean the pilot, since the hole/s are very small. I'm going to guess its a PE 24 carb. Factory Mini may sell rebuild kits but I would try cleaning it first.
Genuine KEIHIN PE Series Carburetors
Keihin has developed high-end carburetors and throttle bodies for years. Don't use cheap knock-off carburetors, get the real thing that will last you and keep you riding instead of wrenching!!Please select a Carburetor from the drop down menu before adding to cart. Keihin PE20 & PE22...www.factoryminibikes.com
I did tear it all down, but this was a year ago and then just parked it. I will have to open up this carb and post pics here for those who know more than I do. I'd like to get it going to bring it out on the trips.When you cleaned it, did you strip it down completely? Did it have a removable seat, and was it push-in, or screw in? Push-in seats usually have an o-ring, and if you put the carb in a dunk can without removing it, the o-ring can be damaged by the caustic solution, allowing fuel to flow around the seat, and not be metered through the needle/float.
I have a pump tester from back in my small engine days to pressurize the inlet and see if it holds pressure.
Here's a link to a rebuild kit. I bet if you call they can confirm the model that I think is a 24.I did tear it all down, but this was a year ago and then just parked it. I will have to open up this carb and post pics here for those who know more than I do. I'd like to get it going to bring it out on the trips.
