Big_Daddy_Jp
- May 6, 2021
- 1,315
- 1,259
I’ve been thinking about getting a train horn for my truck. I was wondering if any of you guys have one, what brand, and what model? They seem to range quite a bit in price. Thanks
If you never want to run out of air, I have what you need. Immediate and constant 150 CFM @ 100 PSI, Rotary screw compressor, mounted underhood, no tank, no waiting. Not only can this run your train horn, you can repair roads using two jack hammers running on one system. Fill your tires in .43 seconds each and annihilate the largest balloons.Yes they make onboard air systems that can run off of your trucks serpentine belt.
it is a nice addition but I am usually towing my toy hauler that would have an air compressor inside so That isn’t something that necessarily need.
They are fun as Eff. Some idiot texting in a 1992 Honda Civic pulls in front of me at 30 miles an hour on the freeway I slam the brakes and simultaneously blast the horn at the same time.
Drain the tank.
abc
Nothing quite says “you’re a baddass” like truck nuts do.
