EastMT
- Jul 21, 2022
- 948
- 611
Where does a guy buy a spanner wrench for King cross over rings? All the cross over ring spanner wrenches I have found are only for Fox shocks.
The lower collars (two rings) that the spring divider stops on.For the collars or the upper piece to add preload?
Smegma? I keep an eye on what people are doing to my shocks and am glad to say that my shocks are smegma free, but thanks for the tip.smegma
You may need 2 wrenches to tighten against each other. I just did the hammer screw driver trick. Also have used channel locks to loosen and tighten them. (in the notches)Thanks, I am ordering the tool in the lower picture. These are the ring I was hoping to find a wrench for.
I've never seen a tool specifically for those lock nuts.Thanks, I am ordering the tool in the lower picture. These are the ring I was hoping to find a wrench for.
If you havent seen one then I'll quit looking. Thanks for replying.I've never seen a tool specifically for those lock nuts.
Where did you find those and what is the brand?
