ANGRYBUTTCRACK
- May 6, 2021
- 1,893
- 1,608
How do I buy a prefab shed
12’ wide x 30’ long x 12’ high ??
Thanks,
abc
Thanks,
abc
First you need to find out if you'll need a permit to set it up. Only the homeless are allowed to put up sheds of any size without permits.How do I buy a prefab shed
Thanks,
abc
But it's in a City that's in county that's in California...........Private property and NO association property.. no permits needed ..
abc
Make sure the homeless don’t discover y0re unincorporated!Nah.. I live in Laguna Hills… unincorporated area.. NONE of that sh__ will matter… trust me … 20 years I’ve owned here….
… just need a MFR .. or distributor..
sincerely
abc
Most areas in So Cal allow 120 sq ' before a permit is needed. Lots of 10x12 tough sheds are sold...First you need to find out if you'll need a permit to set it up. Only the homeless are allowed to put up sheds of any size without permits.
*thank you, come again*
That perfect, that means only the County and the State will fine you and not the association, one less lawsuit,Private property and NO association property.. no permits needed ..
abc
Happened to me in LA.That perfect, that means only the County and the State will fine you and not the association, one less lawsuit,
One Way,
First you will need plans from the supplier, and at the same time have 3rd party do a soils report, start with the concrete company draw up plans for the slab, then also will need to have the 3rd party check the lot line and offsets, then you can send everything to plan check to start,
If you are on a septic you will need to pull the septic plans also for the permit,
Second way
I did a 400 sqft in my backyard, but it was on 3/4 acre and no one could see it from the street, did a carport already had a slab with no footing for a sport cort, then next weekend i enclosed it to make a storage facility, No permits,
But after about 2 years my neighbor went to build one with a permit, and when it was denied, he asked the county why they allowed mine, and that is how i got my notice from the county, but at that time i was in the middle of selling it to build a 2600 sq shop permitted,
That is some of the ways people get caught, neighbors try to build the same thing with permits, or new construction near by and a lot of county eyes driving by,
We did a Mueller Buildings. Nice complete kits, you size it.Nah.. I live in Laguna Hills… unincorporated area.. NONE of that sh__ will matter… trust me … 20 years I’ve owned here….
sincerely
abc
