SOLD 2016 Blazen F395 Toy Hauler 17-Foot Separate Garage. $41,000
J Alper
Site Sponsor
2016 Blazen F395 by Pacific Coach Works,
$41,000 or best offer.
17 foot separate Garage
Not sure where to start, any suggestions will be great, Inside was professionally cleaned, outside i just had washed and fiberglass buffed,
Las year a FLEX-ARMOR roof was installed, this is a seamless roof with Zero maintenance, this is a fiber impregnated spray roof, was around $15,000 upgrade,
Tires, Sailun 637 G-rated 245/85-16 was purchased 2 years ago,
New forged Rims, had a crack in one of the original rims, replaced all 6
Spare Tire is a 637 Sailun
Added 20 gallon Factory Generator Tank kit by LCI
Fuel Station is 40 Gallons with 3/4 line running from the fuel station to the tank, it pump like a gas station pump,
Dual 7 Gallon Propane tanks with built in mechanical fuel level gauges
Upgraded the Lippert level up to a BIG FOOT hydraulic leveling system with 2'' solid steel rams
New style Lippert Screen Doors and New Lippert door windows with build in shades,
Currently has a Goosebox by Popup,
Wheel bearings were done last year with Timken Double Lip Seals
6 Volt batteries were installed in October,
Added a 8 button Switch-Pros to run Exterior unground lighting and to override the front level jacks for easy hitch hookup
Bolted to the frame inside the Garage are 4 5000lbs tie down latches for full size sandcar,
New, Tomas Payne Couches with massaging and heated seats with underglow lighting
Bauer Bluetooth door handles, can run from Iphone,
Furion 3300 Radios in Garage and in Living Room
Kenwood marine speakers on the outside slide
The Items above, i have added to the trailer that did not come standard,
2016 Blazen F395
45'' foot 5th wheel
17' foot Separate Garage
Rear Door Opening is 96'' this has the wider door before lippert went to the 92'' doors in 2018
Dual 7 gallon Propane Tanks
5500 onan with 960 hours
20 gallon fuel tank for the Generator
40 gallon fuel station
15000 AC unit
13000 AC unit in Bedroom
Dometic 1350 Quad Door Refrigerator
System OS runs on Lippert MyRV One Control, you can run all the lights, slides, awning
3 Slides, Main Living Room Slide, Kitchen Slide and Closet slide,
Bathroom is a dual entry bathroom, entry from the hallway and one from the Living room,
Large Island with 4 stools,
40'' Tv running on an 800w inverter,
Bedroom TV is a 21'' with 300w inverter,
Go Power Solar System with one 160w panel,
Two 6 volt batteries,
Happie Jack Bed system with queen bed in garage
Garage has side couch that turns into a bed
Master Bedroom is a Queen size bed,
Propane Stove with Propane Oven,
Suburban Propane Furnace
6 gallon Water Heater, washed and replaced anode last week
Seaflow water pump with soft lines, very smooth and quite operation
Sliding Glass Door for entry into the garage
6 point auto leveling system from Bigfoot
New Bauer Bluetooth door handles, can be locked and unlocked from your phone,
Electric Awning 19 foot wide
Rear Case Awing over ramp door.
Will post the original brochure
Roof is seamless,
All New Vent Covers, and Vents with the new roof
Replaced Bathroom Shower Cover, and added a Maxxair Fan in the Bathroom
And New Cover for Maxxair fan in the Living Room
Will Fit a Full Size Car
Original Spec From Pacific Coach Works
Product Floorplan
Photo Gallery
Blaze'n Luxury Fifth Wheel Kitchen
Blaze'n - Kitchen-Seating
Garage Model LR-Kitchen
Garage Model - Kitchen
Garage Model - Bathroom
Blaze'n Fifth Wheel - Bedroom
Blaze'n Fifth Wheel - Rear Seats
Central Control Panel
Specifications
Exterior Length44'-9"
Exterior Width102"
Exterior Height13'-2"
Interior Height101"
GVWR19,800
Axle Weight10,820
Hitch Weight3,160
UVW13,980
Payload5,820
Fresh Water170 gal
Grey Water100 gal
Black Water50 gal
Cargo R/S17'
Cargo C/S17'
Fuel Tank40 / 20 gal
Specifications
Exterior Width102"
Interior Height101"
GVWR19,800
Axle Weight10,820
Hitch Weight3,160
UVW13,980
Payload5,820
Fresh Water170 gal
Grey Water100 gal
Black Water50 gal
Cargo R/S17'
Cargo C/S17'
Interior Features / Decor
  • 1 Piece Fiberglass Tub Surround
  • A/C 15.0 BTU – Ducted
  • Beaver Tail Floor w/Storage Bin
  • Custom Carpet Kit – Cargo Area
  • Dimable LED Lighting
  • Double Carpet Padding – Bedroom
  • Ducted Furnace – 40,000 BTU
  • Glass Shower Enclosure
  • High Rise Pull-Out Galley Faucet
  • Large Double Door Refrigerator
  • Large Pots & Pans Drawer-Galley
  • LINC PAD Universal Technology
  • Max Air Vent – Living Area
  • Metal Ball Bearing Drawer Guides
  • Microwave Oven 30″ Residential
  • Next Level Floor Covering
  • Porcelain Toilet
  • Rear Electric Bed w/Roll Over Dinette
  • Roller Shade Window Coverings
  • Sani Flush – Black Tank
  • Skylight Bath
  • Solid Surface Tops – Galley & Lavy
  • Stainless Appearance Appliances
  • Stereo/Amp/BT/DVD/SUB/Soundbar
  • TV LCD – 40″
  • Upgraded Residential Style Furniture
  • Washer/Dryer Prep
Exterior Features / Popular Options
  • 40 Gal Fuel Tank w/Pump Station
  • 7000 LB Triple Axles
  • 8′ Ramp Door w/Gray Fiberglass
  • Aluminum Frame Construction
  • Awning – Power w/LED Strip
  • Custom 16″ Wheels – Aluminum
  • Custom Colored High Gloss Front Cap
  • Enclosed Tanks
  • Equa Flex Suspension
  • Exterior Ladder
  • Exterior Utility Command Center
  • Front Diamond Plate
  • Generator ONAN 5.5
  • Gray Slide Out End Walls & Ramp Door
  • Ground Effects Light Package
  • Keyless Entry
  • Lippert 6-Point Level Up System
  • Pressure Washer
  • Roto Flex Front Hitch
  • Sink Cover
  • Slam Latch – Radius Compartment Doors
  • Solar Ready
  • Spare Tire
  • TV Antenna w/Cable Hook-Up
  • Ultra High Gloss Medalion Exterior
  • Walk On Roof
POPULAR OPTIONS
  • 160 W Solar w/Inverter
  • 20 Gal Fuel Station – Gen. Only
  • A/C Bedroom – 13.5 BTU
  • Diamond Plate Flooring – Cargo
    Electric Rear Awning Over Ramp Door
  • Rear Screen Wall
Thanks guys,
I am the original owner, have all the paperwork on the trailer, purchased a Recognition Titled super c i am fixing up,
Probably one of the most dune ready rigs of all time. Also, plus a great seller!
Thank you, my goal was to show up unhook the trailer quickly with the overbuilt hydraulic leveling system, and just roll the car out and put the whip on,
I will add more pictures tonight, I moved the fuel station to the other side (passenger side) like the old Weekend Warriors, this allowed me to park the car to fuel up and not have to move it again back into camp,
