onanysunday
- May 7, 2021
- 3,756
- 3,445
The stock uniballs for the rear suspension are exposed and go away quickly if you put a lot of miles on your car. This was maybe 3 seasons. Outfront John sells a set of 8 seals that pop in there. I put a little grease in there and it appears it should work just like a wheel bearing seal. With much less movement. I believe they will last MUCH longer without getting exposed.
