Jammer75
- 509
List any others you may use.
no but you need corrosion protectionIs freeze protection truly needed if the car only sees Glamis?
The reason I ask is that I run distilled water and two bottles of the royal purple coolant additive. Was not sure if I was missing something by not running antifreezeno but you need corrosion protection
Depends where it's stored. I didn't think I needed to winterize my boat motor living in east sd county but I ended up with a cracked block. I'll never not use antifreeze (or not winterize my boat)Is freeze protection truly needed if the car only sees Glamis?
